boost questin
ive just installed my Profec B II, before i go fiddling with the boost solenoids and the wastegate hose set up, can anyone tell me what stock boost is? ive changed the display to read psi instead of kPa and it seems to sit about 85, i take this to read 8.5 psi. is this about right?
superb thanks, now i can tinker without chasing my tail when i get problems later.
has anyone got any ball-park figures for the profec settings?
Ive got some setting you could try. Will have to get them from my unit when i get home. should give you a ball park figure of around 15psi but all cars are different. When set just take it easy and slowly increase the rev's while keeping an eye on the boost.
thanks a lot!
ive found this link which should help me a wee bit. but if i could get actual settings then id be even closer and itl take less boosting about
