Traction Control Settings needed please
Just spent the day wiring it all up - now I need the settings for wheels as Im thick and cant work it out. :)
Rear tyre sizes are 265/35/zr18
front tyre sizes are 245/40/zr18
is that all I need ?
car is a SWB TT.
what hard cutoff do I set for launch control
anyone be good enough to provide me with info?
Attached are the settings when I read its memory - looks like its already set for 6 cylinders but doesnt seem to be working??
and finally the DAT file (just remove the .txt)
If anyone can help I would be eternally grateful :)
Launch control doesnt seem to work - terminal mode reads it as active but it just wheelspins off
Diags where it does the misfore seems to work tho.
just set wheel sizes to 653mm front
643mm rear.
still unsure as to why configuration reads kmh and any surface is set to 655.35kmh etc
I will try to fine my settings for you when I get home mate.
cheers
I know wheel size will be different buit everything else will prob be same wont it
Hi Jay
First off, sort out your wheel sizes. Your fronts should be 653mm and rears should be 643mm. This will make a difference!
Also, are you sure you've set the wheel channels up correctly? You may need to use the calibration dongle to set the wheels up (if you've got one)
Finally, in your launch control setup, the wet rev limits should be set lower than the dry rev limits!
Steve :)
'93 UK TT Manual
Hi Steve, havent got the calibration dongle but wired it up *exactly* as TTNet said.
I have already set wheel sizes up :)
What is a good setting for wet and dry limits?
Hi Jay
My launch settings are shown below.
However, to ensure that the system is working properly, jack up the back of the car so the wheels are off the ground (pref use axle stands to ensure it's secure). Set the controller to Wet, then run the engine and accelerate. The car should start to misfire at about 10/15mph. This will demonstrate that the wheel sensors are set up correctly or not.
Steve :)
'93 UK TT Manual
