Exhaust cutout
Arrived today.
Going to use it to bypass the silencers at high revs/load and run to an unsilenced tuned length tailpipe (prob side exit). Signal that switches it will also switch ECU maps as there will be one set up for each exhaust.
Arrived today.
What??!!??
do you mean, when you put your foot down its even faster and louder
Yep!! Seen a few guys using these to get through noise tests at Track Days!
Auto switching maps is cool - any ideas what sort of differences you're expecting?! I'm assuming it's going to be a hefty dose of torque?
Rich
No idea what to expect from it yet. Should be siginifcant as I'm running big overlap cams (70/30 30/70) on an NA. As long as the tuned pipe length is right it should be as good as you can get the exhaust system power-wise.
Don't knwo if I'm just getting old, but sometimes wil be good to have the quite system for around town etc. Did feel like a bit of a cock with the old system on the turbo sometimes. Sounded awsome on the open road but a little embarrasing when old ladies dropped their shopping!
Lol, basically yes :D
so...you'll effectively have two exhausts?
thats kinda mad - i like it!
Yeah I could here you starting it from here. :rofl:
Like a screamer pipe??
Screamer pipes are usually wastegate outlets on a turbo car. This is just bypasses all the silencers.
