Leather Heated Seats
FORGOT TO MENTION THIS IN OTHER THREAD SORRY GUYS, I HAVE LEATHER SEATS IN MY Z ITS A 1992 TT MANUAL UK SPEC, IV NOTICED THERE ARE WIRES WHICH ARE NOT CONNECTED FROM THE SEAT WIRE HARNESS, I HAVE BEEN TOLD THEY WILL BE FOR THE HEATED SEAT HEATRS, HAS ANY ONE GOT A WIRING DIAGRAM AND ALSO WHAT TYPE OF RELAYS I WILL NEED AND WHERE I CAN GET THEM FROM, IV NOT TRYED CONNECTING THERE WIRES DIRECTLY AS I DONT WANA DAMAGE THE SEATS, PLEASE CAN SOMEONE HELP ME. BOTH SEATS ARE ELECTRIC AND BOTH HAVE WIRES WHICH ARE NOT CONNECTED.IF ANYONE HAS A WIRING DIAGRAM PLEASE CAN YOU MAIL IT TO ME AT SISQOSAF@MSN.COM TNX
Do your heated seats work? There should be a pair of switches in the centre console, after the ashtray that controls the heating elements. If they don't work, you need to ask yourself why they have been disconnected. If it's because the original switches don't work any more, you can run a feed from the cigarette lighter via a pair of new switches to get the heating elements to work. I believe that the drivers has a seat and backrest element ie 4 wires and the passengers seat only has a seat element ie 2 wires.
Good luck
Jack
hi jack i dont have the switched there its just the mirror switch they have never been connected i prusume as there is no switches, but yeh there is 4 wires driver seat and 2 wires passenger seat! the problem is i dont know how to connect them ie dont know which is earth and also if i need relays tnx. any help would be appreciated
Good luck
Jack
Are you sure they are heated?
If the seats have been salvaged from an earlier car, they had a weird pre-tensioning system in the seatbelt buckles that is connected with a 2 pin connector that dissapears under the carpet. This cable then connects to the recoil of the belt to reduce the tension in the belt.
I think it was removed from later models.
hi mate yes im sure they are as the wirin is all there and seems correct as confirm by few peps i just need the wring diagram or some one who knows what colour wire is what cheers
The wiring is relatively easy. Remove the surround around the ashtray ie the whole fascia and surround around the gearlever. Find the big feed to the cigarete lighter, witre this to 2 new switches that will need cutting into the fascia then run cables under the carprt from the seat wires. It dosn't matter which you connect to as you'll need to connect a return wire on the other seat wire to take the electricity back to earth.
Do the same with the drivers seat back wires, but have these connected to the seat feed/return so that they come on at the same time as the seat squab.
So, flick a switch and you have heated seats.
I did this after sourcing a pair of heated seaats from a breakers yard - and from memory (since sold the car) they don'tt get too hot if left switched on - I presume there's a thermostat in there somewhere.
Good luck
Jack
cheers for that mate, i gess there aint any relays to connect then iv been tryin to locate the where the relays should be and also have found ot that there should be a separate seat timer box on the front driver side near the foot well!! been tryin nossan but they usless they dont know what they talkin about.
Good luck
Jack
I think I've got one of those boxes/switches. You can have it if you want. I've also got the connectors for it. But, the problem is, none of it matches the wiring loom of your car. I tried to install it into my car but gave up as it's far too complicated.
:nana2: hi jack well what do you want for the stuff mate? ill be happy to take it off u if its no good to u nemore, i was actualy start on the seats 2morrow theres a 3-4 black wires on the driver side with 2 colour and 2 black wires on the passengr side u dont know whats what do u? will any be earth? my number is 07834 033833 o you can mail me direct on sisqosaf@msn.com tnx again mate
You can have the stuff free (assuming I've still got it) - just let me have your address and I'll get it in the post.
Re the wires, use the blacks as the feed wires and the coloureds as the earth wires. As I sad before, I fastened 2 switches left of the clock and wired the seats to these and wired these to the cigarete lighter (it's a heavy feed).
I think that the seats have thermostats in them as they never got too hot - it wasn't as though you were switching them on and off all of the time.
Good luck
Jack
:hyper: tnks again mate iv emailed you my address here it is again 5 crosshill road , blackburn, lancashire, bb2 6pr. let me know if you do find them and ill let youknow how i get on cheers
Good luck
Jack
Got the switch and the connectors - there are 12 wires in total coming from the back. When I tried to use it none of the wire colours matched the loom that was in my (Jap) car so I gave up. Also, the switch does both heated seats and has the mirror adjustment on it too, but what it doesn't have (as it came from a UK spec car) is the switch to fold in the electric mirrors that come as standard on a Jap spec car.
I'll put it in the post.
Good luck
Jack
tnx mate realy appreciate it will let you know how i get on , mines a uk spec car hopefully should be ok if its out of uk car.
Good luck
Jack
As yours is UK, you should find that the extra (over and above the wires of your existing switch) wires that come out of the switch I've sent, will be for the heated seats - you might just be able to figure it all out.
Good luck
Jack
Good luck
Jack
hi mate tnx the switch arrived this morning looks great unfortunatly the wires dont match with mine either so going to be a head ache sorting them out! iv split the wires thu separated the electric mirror wires which has left me with 5 wires need to find out what they are for, a guy called andy on here has the wiring diagram as iv read a post were he said he's emailed it to the guy but as im not a fully registred member i cant contact him :( , ill have to nabage without it tnx for the switches again cheers
