ecu temp sensor wiring!!
hi guys as u know ive got misfire and poor performance problems, went to the temp sensor today after a hint of one of you good chaps and found to my disbelieve that the plug is not the orginal one, now as someone has re-pluged it could they have put the wires the wrong way round? if so which way round should they go??
regards andy
regards andy
there colour coded andy just peel the wires back and check, then reinsulate wires
it may just need a cleanup, i did a write up on cleaning sensors etc, check the FAQ area
so the the sensor is colour coded aswell?? the wiring loom plug is missing and he has put two spade connectors straight onto the plug!!!!!!! :shock:
regards andy
Doesn't matter which way round they go bud ;)
