what do i need
i can move the hicas arm up and dont about an inch (where it attaches to the hub) clearly its fooked. is it the ball joint bit or the bush inside or both? with this cause my rear wheel problem. when i feel the rear wheels it feels as tho the wheel bearing has gone. i have a video, where can i upload it?
ball joint is absolutly shagged there mate, new lower link ball joint needed, normally associated with the car skipping out when you hit a divet etc
do you get any rumbles from the rear[no pun unless a lamb bhuna went down bad the night before]
a wheel bearing normally shows up with play from left to right, possible rumble vibration from the wheel?
but as said looking at the ball joint to the hicas looks a bit excessive there
limit of movement should be 0 vertical play if you pull between lower link and ball joint is there any play? if there is replace
the other side doesnt move at all. but the othere side is what is causing my probs. i can turn the other wheel about 5 degrees but there is no movement in the ball joint. what else could it be
when i hit anything in the road the car jumps all over the road
