stalling problem found
Well i had a stalling problem and some other people had the same problem wher you go about 40 mph or over and put in the clutch or shif in to nutral and the car would die after struggaling for a few moments well i installed a cold air intake and replace all my vacume lines it nolonger dose it i think what happend was the big line on each intake tube that gose in to the engine had a pipe cleaner broke off inside of it on both sides thought id share this info
And in English ....?
Hi,
Well, I had a starting problem which i believe a few others also had, It was when the car was travelling at around 40ish mph. If i drepressed the clutch or shift into neutral, the car would seem to struggle, maybe even stall.
I fitted an Induction kit and replaced all of the vacuum pipes, this seems to have cured the stalling problem. I think what happened was that the larger pipe that goes onto the engine seemed to have broken. I think this was due to having, what looked to be a pipe cleaner blocking the flow.
I just thought i share this information with you all.
(i think) :rofl:
yea way to go fellas. flam the guy for posting something that might be of help to someone.
thx chunk for puting it in english for me the large pipe im talking about are the pcv lines whanted to clear that up
The PCV lines are supposed to have the "pipe cleaner broken off" in them - its a flame arrestor ;)
Duffers = "Fountain of all Zed Knowledge" :bow:
(How the fook did you know that?)
LOL cos I've replaced loads of them ;) Now where's the geek smilie? :rofl:
well i dident find any replacement broken pipe cleaners to drop in frome nissan courtesy parts.
