Big Boost Leak!
I took the Zed for her 2nd attempt MOT today and she's passed! :D
Whilst running to and from the MOT station, I think I found why my new tubs aren't producing any positive boost! I have a huuuge boost leak (constant pssst on idle) which seems to be under the passenger side of the plenum. I'm guessing that a pipe has popped off as the plenum was only recently refitted...
Any ideas what pipe this may be and is it likely to be repairable with plenum in place? If I can get this sorted by the weekend, then maybe I can take her to the rolling road day after all :dance:
Many thanks for any ideas!
CheerZ
Steve :)
'93 UK TT Manual
av you got a boost leak detector steve. can get one to you via post if not. pm,d you my number
or I've got one you can borrow. I'm not too far away either. ;)
whats sat bud
surrey rolling road day :dance: that steve has been organising for us lucky buggers lol
Thanks for the replies fellas :bow:
I've got a boost leak detector but I'm not sure it'll help much as it's hissing away like a goodun anyway when the car is idling. I was just hoping to get an idea of the possible vacuum pipe culprit under there :)
I've got a spare plenum in the garage so will take a look at that tomorrow :cool:
CheerZ
Steve :)
'93 UK TT Manual
Only things I can think of 'down there' Steve, is boost solenoid piping and of course the hose on the tub itself??
*GULP* fingers crossed it's off the solenoid :rolleyes:
CheerZ
Steve :)
'93 UK TT Manual
On the other hand, if you use the detector you can listen closely for leaks without risking burning your ear. ;) Do you think it's actually under the plenum or just to the side?
Maybe the diagram helps? http://www.300zx.co.uk/cgi-bin/manual.cgi?list=efec&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=12&design=default&total=190
I only had a quick look today Dave - will have a proper check tomorrow morning :cool:
'93 UK TT Manual
Found it :cool:
First off, supported the bonnet with an appropriate bonnet stay replacement...
After much faffing, I discovered that the vacuum pipe from this connector on the plenum had been trapped under my front strut brace tower and had been damaged...
Should be able to replace this (if I can find out where it goes :rolleyes: ) and be back in business for Saturday :dance:
I also found this connector was unplugged (front left of pass side suspension tower). Is this one of the stock boost solenoid connectors?
Steve :)
'93 UK TT Manual
Just been out for a test drive and I'm boosting again! :dance: Just need to setup the Profec B now and should be in business :cool:
CheerZ
Steve :)
'93 UK TT Manual
Congratulations bud! :hyper:
Will be good to see you Zedded out for the first time in ages!
