alternator
i think i whant to replace my altinator b/c my belt will not shut up its ajusted right and it screams i tryed tighting and loosining it so i think my alt is dragging so i am looking at the alternators i have a big speaker system and a 1200 cca batt so im thinking if all the diffrance between the alternators are the amps ill go with the higher one to charge my batt faster
90 2+2 n/a
Get a TT alternator...those deliver a higher amperage.
90 2+2 n/a
A little tip that works is to drill out the curved adjuster bar where the main adjusting nut/bolt stops by around 1/4inch,(more if you wish)this will give you plenty to adjust up the belt,.
Tony :)
be careful with overtensioning the aux. belt(s)
it can cause excessive wear of the main crank bearings
well i could tighten it untill it snaps and kills my berings and my belt would still squeak so i need to eliminat drag and i think my altinator is dragging some one said a tt alternator but what years a 90-93 94-96 ???
Do you have a UD pulley?
