I got these with the brake package I got, but the connections seem different to the ones from BSR I got a while ago. I'm pressuming that the bolt (with a hole through it) fits in the end with a loop, but how do the other ends fit?
Vijay
The end that fitting you are talking about is called a Banjo fitting and presumibly fit into the caliper using the same thread as per standard.It looks as if its a slightly different version of others available, not sure why they used Banjo fittings maybe more readily available?
Jeff TT
Ps there should be copper washers with the banjo fittings to seal when tightened.
On looking at your second picture it looks like they are the wrong set as the other ends of the fittings will not match up with the stock pipework.
[This message has been edited by Jeff TT (edited 03-04-2002).]
cheers Jeff, yeah I have got the washers and that's what I thought about the other ends. I'll give them a call tomorrow.
Vijay
Does Jeff or anyone else know the correct lengths for the brake lines?
Vijay
