protoj · Tuesday at 18:48 3 days
Is it just me or are there loads of zeds in nottingham?
I keep seeing loads but the odd thing is that im never in my car!!! Everytime im in the megane with the mrs or with my mates............i see a zed! DOH!!!
So come on, who are you all??
LUKE DUKESTER
