Replacing studs
Hi,
Had a look on search and couldn't find anything, does anyone have any links on how to put in longer studs on the rear, i need to put on 20mm spacers, i tried the other day and it looks to me that the hub will need to come off any ideas?
Cheers.
Take out 2 bolts to remove caliper, make sure handbrake is off. there is nothing holding the disc on then.........
Hi,
Cheers.
Yup the hubs have to come off and the studs in the rear are not the same as the front studs. The splined part of the fronts is on a shoulder and 14mm diameter where are the rear studs have a much smaller shoulder and a 12.5mm diameter on the splined part.
