Steering wheel
Have ordered a new steering wheel. Whats the best way to get the standard one off. Is there a special tool i need to use. Thanks
Pull of the plasic centre, undo the centre bolt but leave it on a couple of turns. Then pull like hell. it will come off all of a sudden, hence leaving on the nut, otherwise steering wheel in the face! Thers the horn cable etc then.
Make sure steering is dead straight before removing so when you put new one on its straight!
undo the main nut 2-3 turns and hit the nut with a sharp single blow with copper faced mallet,this will "shock" release the taper ;)
I used a puller from work. But I had easy access to one.
If you dont, whack it.
Thanks guys, will give it a go.
