ok well i have a belt that squeals i dont think this is related but when i drive and get to about 40 and shif in to nutral the car dies but it only dose this around 40 or higher it will sit and idle fine but if your rolling and you stay in nutral it will die any advice other than not to shift in to neutral
You don't seem to be getting much help here. I know this has been discussed before. Try using the search button at the top. I will look also.
Found the exsact same problem i had to use stall insted of dies so a search for Constant stalling! thats my problem and ill try som of the sujestions later today
Ok the post dident help as soon as i hit 35 40 and if i shift in to nutral or put in the clutch and le off the gass it struggles and dies im thinking a vacume some wher but i dont know wher the vac lines on this car are and if my altinator is bad could this be the culprit i think my altinator is making a bet sqweeal but not positive and if i have my ac on the car is grate
