removing standard rear spoiler
just a wee bit of advice please,removing standard spoiler is there any step by step guide of how to do it on here anywhere,also just below the spoiler where nissan and twin turbo is written (black strip)whats behind it,its getting taty wanna peel it off any one done it,cheers :dance:
The tatty bit can be replaced with a plastic one from Z Centre for about £35 IIRC. As to removing spoiler I got someone else to do it.
cut the clips off from the front corners, then pull it for all you are worth, it will come off quite cleanly that way. You will still need the tailgate resprayed though.
Just had mine done at the bodyshop. The nissan/twin turbo emblem didn't come off mine cleanly so we have left it off the new spoiler. The back end will have to be resprayed though unless you are fitting a replacement. Use a very firm adhesive compound if you are doing this because the replacement spoilers tray to peel themselves off from the corners.
The stock rear spoiler is held on by two threaded studs and six plastic clips.
If you dont undo the nuts on the studs then NOTHING will happen no matter how hard you pull. except you will fook the spoiler AND the tailgate. It is also sealed round originally by adhesive tape.
IF it has already been off once before you have to consider the posibility that it may have been re -applied with Sikaflex or similar, in which case you will need to use "cheese wire " to saw thru that.
If your spoiler is beyond re use and you just want a stock replacement then I have one available. CAREFULLY removed, flatted down and primed . Ready for colour coat and re fixing
