Accessory Belts...
only differances are as follows
uk alternator belt is slightly longer than the j-spec,due to the waterpump pulley wheel being larger so in theory puts water around the engine quicker
so for a uk version
alternator 1040
air con 965
p steering 925
j-spec
alternator 1015
air con 965
p steering 925
only other differances are NA power steering is a 2 rib vs a 3 rib for the twin turbo
unsure of part numbes,however if you wish to get non oem,these numbers above may be useful
Just 1 thing though, the N/A is a 3 rib and the TT BEFORE 94 is a 4 rib, over 94 TT model is same as all N/A's.
Just incase you got a bit muddled mate :)
cheers
smithy
cheers
smithy
yer long day and all that :wack: :)
???? other way around surely, the larger pulley will turn slower.
Good upgrade to a UK car is to fit a Jap spec water pump pulley to improve water circulation.
Daveman
I doubt there is much concern over that on here lol plenty of people put on underdrive pulleys, much smaller crank pulley and larger pump one.
