boost leak help from drivers side
cars been running fine and hitting 1 bar etc but thought i do i leak test as im on hols and theres a large amount of noise coming around the drivers side lower engine area ,cant seem to find it .
is there anything around there that can cause this ??
thanks
the pipes coming from the tub themselves, found mine were very loose
are these bolts ??or hose clips and is it a under car job etc .
does anyone have a photo etc
thanks for the fast help
hose clips,look straight down from the cruise control unit in the engine bay,you may need a torch
i owe you a pint .it was the bottom clip .
many thanks :bow: :bow: :bow:
Hi vai0, was this easy to get to mate as I have a 'similar' problem
it wasnt to bad.the top hose clip is easy if you have a hose clip flexi drive 8mm one.
the bottom one i use a small 8mm spanner on ,
took me 5mins
took me 5mins
CheerZ
Are the both accessible from the top or underneath ?
CheerZ
from the top very easy to see them .
