As shown in picture there are two hoses near n/s turbo with bolts tightened on the ends, are they supposed to be connected to eachother?!? or are they supposed to be like that? My Z is still boosting at 6-7 psi, help pls. :headvswal
P.S. The connector on the blue arrow is the T type one.
looks like the old oem boost control pipes to the wastegates and solonoid so you must either have a boost controller or its had one :)
I dont have a boost controller, is that the reason I have low boost? should they be connected? can't you tell I am crap at this?
very possible as the turbos will just boost on the wastegate which is prob 6 or 7 psi!!
i would get a boost controller which should give you what you need ie booooooooooooooooooost :D
Hoses reconnected, and what a f****g PITA to get to :rant: boost back to 9 psi though :dance:
nice one, will be boosting on the stock solonoids now :)
at least you will know where to plumb the boost controller in if you choose to fit one ;)
