Rubbers that the bottom of the rad sits in? Changed my fan last night as it was cracked. Did it with the rad half in and the water pipes still connected as was being lazy! Couldnt get the left side back in properly and the rubber fell out the bottom of the car doh! The right side is still in and it still seems pretty tight, the left side is held in place by the pipes as well as the top mount so shouldn't be a problem should it?
the rubber gromets the rad sits in support the rad and stop it chaffing and rubbing through on the body. I would find it and replace it if I was you.
yeah but that means i have to pull the rad out for the 3rd time this week!
ill keep hold of it and put it back in next time me thinks.
no just remove the top clamps and lift the rad with pipes etc still fitted and put the gromet in from underneath. easy and worth doing
pj
yep put it in bud or you will get ultra high vibes coming from body and it will damage the core, high freqency vibrations do more damage than people think to delicate conponents such as rads
Yeah ill do it tomorrow, jack her up and get a mate to hold the rad up a bit.
