Subframe bush help
Just got the first bush out with the drill and hacksaw method. The bush came out with a steel cylinder attached, about 3mm thick wall. Still in the subframe is a thinner wall tube which has a lip one end, which has obviously been sawn thro, and a ring of rubber the other end. Question, is this part of the bush or part of the subframe? Ta.
keith go here, massive section on the rear subframe and bushing removal replacements with photos i put up.. will tell you everything you need to know.
http://www.300zx.co.uk/forums/forumdisplay.php?f=54
