Got my car back but...
Picked up my car today having not seen her since Japfest :D
Great to drive her again although taking it a bit easy on the new tubs. Boost controller not set up yet.
Unfortunately she failed her MOT on a pretty serious rear subframe rust issue :( Going to get it looked at next week and hopefully get it sorted asap! Maybe then I'll be able to get to some of these South East meets I've been hearing about ;)
Just nice having her back home again :cool:
CheerZ
Steve :)
'93 UK TT Manual
No way! Sods law :rolleyes:
Hope she's all sorted soon Steve- I don't think I've ever actually seen your Zed! :rofl:
oh what a bummer :( Hope it's not too expensive to get sorted and you can get in done pretty soon. All the best
Hope you get is sorted soon Steve,the rear subframe can be a ball ache to replace.
Thanks guys :) Going to get under there today and take a proper look.
LOL - Reading meet, 12 January 2006 :tongue: I can't believe you've forgotten :D
Steve :)
'93 UK TT Manual
Steve :)
Deffo mate, I think with yours being a UK spec as well, you often see the rear sills section rust away and if left untreated it moves inward under the rear suspension unit and into the rear floor pan. Worth removing rear seat and pulling the carpet back to check for any signs. Have seen a couple of cars at Zedworld where the rust had travelled across rear floor pan so much, they were scrapped :eek:
Just done both sides of mine, all rear sections cut away ( 4 each side) and replaced with new ones to right under suspension and approx 3ins into floor.
Biggest culprit was the drain for rear targas, it has a small piece of steel attached to the end of the rubber hose, these easily rot away, so replaced mine with S/S at the same time. Now shes rust free anywhere around there and good for years to come :dance:
cheers
smithy
cheers
smithy
Cheers Paul :bow: Fooks me right off though because I almost never drive her in the wet and she's been tucked up in the garage for the last 10 years :rolleyes:
Will take a couple of pics and post up what I find...
CheerZ
Steve :)
'93 UK TT Manual
hope you get her sorted soon m8 typical uk car ...lol
LOL :slap:
'93 UK TT Manual
Steve,
You were just saying the other day how long you had been without her. Now you have to wait some more, bummer.
Good meeting you the other day and lights are perfik.
Colin
Steve,
Colin
No worries bud - good to meet you (briefly) too :)
'93 UK TT Manual
Right, I've been under the car and taken some pics.
MOT failure sheet states: Nearside rear subframe mounting prescribed area is excessively corroded [2.4.A.2]
Here's the mounting point...
Here's the worst part of the sill.. (the hole wasn't there until I started having a prod - it's fooked :rolleyes: )
Here's the distance between them...
And finally this is the rest of the sill moving towards the front of the car...
The area around the mounting has only a very small amount of surface rust and seems solid. The sill itself is obviously fooked. I want to do a proper job of sorting this before my side skirts are fitted.
Is this similar to the problem you had Smithy? What sort of job (difficulty/expense) was it to get sorted and are there any replacement parts required?
Any input on this is really appreciated... :bow:
CheerZ
Steve :(
'93 UK TT Manual
I just had to get my rear sill re-welded to pass the mot its an unfortunate issue with these cars as they age. If you speak with jeff at zed world he can supply a patch panel that can be welded in place of your exisiting sill so that would solve the issue and give youa bullet proof sill for years to come. I went that route and found someone that would re-spray and weld it in at a weekend cash in hand.
I had some sill rust that was like that but worse. Cost me £600, but the guy rebuilt both sides, I had to fill on top and re-do the body work.
Thanks for the info fellas :bow:
I've got a mate who's a retired welder and another who runs a bodyshop so hopefully I'll be able to call in a couple of favours ;)
Steve :)
'93 UK TT Manual
Does anyone know where the targa drain comes down?
I guess I'm going to have to hack off the corroded section anyway :rolleyes:
Steve :)
'93 UK TT Manual
