urgent help - in middle of brake disk swap!
I couldnt find a guide on here but did see pointers like keep the caliper supported so....
I saw the 2x 19mm bolts that looked to hold the caliper in place and removed them, sure enough the caliper came away and I rested it on an axel stand so not to stress the pipe.
the disk came away very easily and i swapped it for the new one. So far so good and I was feeling very pleased with myself never having tried brakes before!
Now I can't get the caliper back on! Do I need to remove the brake pads first? and If so, how?
Please help as I want to go to Modified madness tomorrow!
Yes, you will need to remove the brake pads, plus you will probably have to push the pistons in a bit too.
