Process To Replace ECU
Sy, YHPM dude
Rich
disconnect negative on battery,remove passenger side floor mat,remove 4 bolt on wooden panel and remove,remove the 3 bolts on the ecu bracket,remove the ecu gently dont stretch the wiring,unscrew the 10mm bolt holding the blue plug in to the ecu,separate the ecu from the bracket(4 screws) then reverse for refitting.i am no mechanic and it only took me around half an hour!! good luck
