Is it a minor job....
To change the autobox oil and clean filter id like to do it myself :eek: ive done little things on the z but this ill call my biggest :) .
if you have a drain plug then its easier because you can drain oil first & then remove sump otherwise, if you dont have a drain plug it can get messy as theres approx 3 litres of oil, theres few 10mm bolts which hold the sump undo them to remove sump then you will see the oil strainer which is held by 3/4 bolts undo to remove give it a good clean then do everything in reverse order, then refill through the dipstick check level while car is running.
Thanx nad300 ill give it a try weekend it dont seem too hard to do ah :)
If its an N/A then am sure no drain plug(unless one was fitted by a kind owner at one point) on them(as to why this is, no idea),Tony
