brake problems
help!
iv lost aall braking power...pedal goes straight to the floor and barely stops the car! argghh
recently had the braked bled, could it be a problem with this?
or is it somthing a bit worse??
any ideas?!
could be master cylinder failure, was the fluid topped up properly when you had the brakes blead? if not the air may have got in there! also is there any sign of any leaks under the car?
i will check in the morning for leaks
the brakes were done at local nissan dealer maybe 6weeks ago, had no problems till fri night, seems a bit strange.
well personally i would go back to the dealership and ask to speak to the complaints department, that normally gets me answers pretty quickly, infact it normally works everywhere.
will do, only prob is i go on honeymoon for 2 weeks on tue and havent the time to get there before i go
will kick up a fuss when i get back tho
