I'm going to replace the timing belt on my 1990 300zx that has done 220.000km. Do I need to replace the idley pulleys and auto tensioner??
deffo, Courtesy do a 120k kit which is what i done on mine, includes belt, tensioner, idlers, water pump, cam/crank seals, water hoses, thermostat, VVT springs etc.
Variable Valve Timing, just go in the inlet sprockets. you need to remove them if you want to replace the cam seals (which i did)
