After searching the 'net, I found a couple suppliers had them in stock. First being Torquen - albeit at over ยฃ600 for a pair for either cast iron or aluminium.. Then I found some fully rebuilt aluminium ones (the correct fitting for a TT) at less than half that, which got me thinking. Cast iron vs aluminium....??
Opinions please - good or bad๐
RichardS ·
Any recommendation on where to buy the above and how much one is expected to pay for them.
ย
Many Thanks.
