what are these? there is a loose wire and a blanked of pipe. there is a similar blanked off pipe on the other side also attachment.php?attachmentid=24676&stc=1
is that an educated guess at what the wire used to be from? lol
it mite be for that as it has had the cats removed. im in the process of removing engine and it was taped up. any idea what the two blanked off hoses are? heater matrix?
That looks like an oil cooler hanging at the front mate. You wana get that hooked up somewhere, or it'll catch on the road as you drive!!
yes that is what they are. cheers
that is an old oil cooler. its a nightmare bein down there. it keeps catching on everything. speed humps are a no go. is it not supposed to be there lol
...wait a minute....I guessed the AIV removal...surely that gets me a booby prize dont it???????
clue----> :duffer:
glad youve solved your problem :cool:
It looks like the wire for the oil pressure switch mate. also the hoses blocked up are the EGR pipes I believe.
PJ
what are egr pipes?
my oil pressure gauge never moved. (not that they are much use anyway)
Southwestzmech It looks like the wire for the oil pressure switch mate.
I've just replaced my oil pressure switch and can confirm this.
