What presure should it open to let oil into the cooler?
Mine only allows it through at 6 bar which seen to high and the oil as a result gets too hot for my liking.
shouldn't it be around 4?
So Someone is it 4 Bar???????????????
Guy on TT Nett recons so just looking for final comfermation that my regulator is fooked
Mark, probably better replacing it with a sandwich plate offtake and a thermostat.
Becomes temp controlled then rather than pressure and tends to work better.
Oil temp should ideally be 80-110 deg C. 130 is very bad, not sure where yours is.
Probably up at leons this wekend doing the V8 intakes if you want to drop over.
Hi John I have a Greddy sandwich plate on and was going to do this at on friday. + I have a thermostatic valve. I was just a bit concerned at loosing presure, because the regulator would in effect be byepast.
What day? and are you still up for doing a bit of on road setting up?
Would need to have a look at the diagrams but I'd imagine you'd be best to block the original cooler lines as its a bypass system. I think the pressure valve to the cooler is separate from the main pressure relief valve in the pump.
The greddy plates I have seen don't have big enough off takes for a cooler, you need at least 5/8" (-10 or 5/8 BSP fittings, preferably 3/4").
You sure cos the original cooler out puts are only 10mm. So thats what I got from cooler to feeds.
Yes, but the original system doesn't flow the entire amount of oil going around the system, it just bypasses some of it off. With a sandwich plate, the entire amount goes through it so you need bigger pipework to minimise pressure drop.
