question 4 jefftt
jeff just read your diagnose for that gunge?
after picking up the Z from chip away bloke (see KEYED string) i noticed that there was some silicone looking gunge onder the area of frount off side rust in frount of wheel. i also have an annoying squeek on road bumps. could this be due to silicone leak from sub frame bush like you were on about, if so will polly bush upgrade fix. this is a never ending train this Z!
I know how u feel about the never ending bit mate! I'm about half way through the never ending zed story i think!
LUKE DUKESTER
Front tie rods or tension bars whatever you want to call them have silicon filled bushes thes often splits and drip out, cheapest fix is poly bushes as the rods are mighty expensive at Nissan (about £250 pair)+ fitting.Sqeeking suspension can be just dry bushes or can mean worn bushes, needs a visual to be sure.
Jeff TT
shuuld have said at solihul cant belive getting more problems this is anightmare BEST WAKE UP SOON OR BE BAKKRUPT!!
someone give me alarm call
