Fluid from 2 pipes on radiator
Ok guys I replaced my alternator on Saturday and when removing the radiator i disconnected the too small pipes on the bottom of the radiator and a red fluid came out, (looked like power steering fluid) im guessing this is a cooling device on the bottom of the radiator? can any1 tell wat fluid it is as ill need to top it up..
Jay
ATF and i would suggest that you fit an aftermarket transmission oil cooler bud.. prolong the life of your autobox.. ;)
Cheers man ill have to get that topped up. where do the aftermarket coolers be positioned?
in font of the rad where the engine oil cooler is. (under the airfilter beneath the headlamp panel)
top it up thru the dipstick tube..
Cheers man useful info there.
Jay
