auto box temp
Does anyone know want the operating oil temp range of an auto box is. i have searched on google and not found anything.
The reason i ask is im going to be fitting a temp gauge into the oil pipe going to the cooler so it will read the highest temp. and just curious of what it should be.
*should* be between 50-80C.
without a decent oilcooler temps can get much higher then that (100+) and is one of the main causes for Zed autoboxes to blow up as (regular) ATF will loose it's protection/lubrication properties starting at 120+ (it will start to turn brownish or in worst case black and it will start to get the burning smell)
great idea i will probably do that myself
Chris
