Blitz Power Meter
It's a version 2 that goes with the Dual SBC-i-D boost controller.
I've never really got this working in all the years I've had it.
It's facing the boost controller for it's infra-red link and I've calibrated the speed and entered the weight of the car, tried adjusting the power loss value which I was told you don't really need to mess with.
Problem is the power figure it displays is way out - it says I'm peaking at about 102bhp! LOL
I presume from the way it works it out that this will be an at the wheels figure and the power loss +/- setting allows you to alter this?
Any ideas?
have you set the Units to kilograms for weight or pounds and enetered the correct weight, and is the power measurement unit to "hp" and speed unit to "mph" . Most people set losses at 0%
If you have a Jspec with a MPH conversion i thinik you need to use "Kmph" as the speed unit though?
I think you can only enter the weight in pounds? which I've done after a getting the car on a weigh bridge.
Power is in HP and speed in MPH.
Power loss i've had at zero and tried various other settings but still not right.
It is a Jap spec so I'll try it in KMPH and see if that makes a difference.
