oil level on dipstick
Ive been told i you have main seal leakage to try only having 3/4 of the oil on the stick?(ive changed PCV valves and hoses)will thinner oil also help?
Is this when cold or warm?
Basically mate,if a seal is leaking,it's fooked!-the only other thing I would reccomend is Forte Seal Conditioner,does work but not in all cases :)
Would a thinner oil not leak more - being thinner it would surely seep through a smaller gap?
Richard
Richard
I thougt maybe thnner oil would reduce oil pressure resulting in the oil not be being forced out as much
Ive been told if the mains seal is leaking try only putting 3 quaters of oil showing on dipstick...
Why the fook would you want to lower the oil pressure!
Just get the seal and get it done, its a small problem at the mo that will soon be a big one if you try to sidestep it.
Rich
Oil level on the dipstick should be half way between the MAX and LOW not at max as most people put it as when the engine is hot it will be over filled.
.................Rich
Exactly - lowering the pressure will end up causing more engine damage than just having a leaking rear seal.
Think how hot these engines get, in this weather a decent oil is essential mate - oil pressure being too low will kill your engine :eek:
Richard
