OK i know what the compression shold be.
only did the front 4. O/side 60psi 60psi N/side 60psi 70psi is this poss?
i do 300miles a week in this car and get well over 20mpg.
only did test coz had a power run and 10% down. (only 5% on torque)
would the car still drive ok? how slow would it be?
did you test the comp with the fuel pump fuse out and the throttle bodies held open.was the engine hot when you ran the test.funki si,s engine ran pretty smooth even though the n/s/f piston had picked up and the piston land had broke away giving him virtually zero psi!!
