Advice
ok lets say you have new turbos fitted and lets say the drivers side is bellowing smoke out on tick over like it was when the old turbos were on ,what would you do?i have had about enough of this car.
Take it back to the person who fitted the turbos, as they are under warranty
The person who fitted them and the person who supplied them are different.
Have you done a compression test? My first zed was throwing out black smoke so I reconned the turbos thinking that would be the problem. Numpty here didn't do a compression test though and it did the same with the reconned turbos. Turned out I'd been running very lean due to boost jets and crap turbo gauge and had blown two pistons! Hope this isn't your problem!
So just to start at the begining mate so that you may not have to automatically blame the tubs.
Was your drivers side the only 1 smoking before and now it's still smoking on same side only now with new turbo on ??
smithy
Had new pcv valves,and before turbos were changed both sides were smoking.havent done a compression test with the engine in will get that done prolly tuesday at zedworld.The car wasnt smoking at all until i took the cats off
When did you take the cats off before or after you had the new tubs?
Had the exhaust done ,and the day after smoke and lots of it,didnt smoke at all before ,now i changed the turbos the one side is perfect and the other is only blowing on tick over.
You are doing the right thing, taking it to Zedworld. You will get a professional diagnosis, and not end up carryingout costly unneccesaary repairs on an illimination basis.
