June 29, 200619 yr Well I think I found my boost leak last night which pleased me as I'm about to fit a boost gauge. What I need to know is do I still need the boost sensor if I'm not going to use the factory boost gauge. Next question is, I have a swoosh boost gauge and the instructions don't state which wire is live and nuetral, black or white, anyone know? Cheers Scrawn.
June 29, 200619 yr If you don’t want the factory gauge to work, then just leave the factory sender out of the vacuum loop Normally it would be black ground, white +12V
June 29, 200619 yr Author If you don’t want the factory gauge to work, then just leave the factory sender out of the vacuum loop Normally it would be black ground, white +12V Cheers buddy :bow:
Cheers Scrawn.
