In memory of Mandy
adjustable front camber arms
no differance
Erm fraid there is. Driftworks upper arms are both R32 and Z32 fitment.
In the early days it was said r32 upper arms fitted the Z32, which they did pretty much, however the offset between the 2 cars is different and hence incorrect offset can cause the unit to collapse after rubbing inside the cradle.
more info here in this link, click the pic to enlarge wording.
http://www.300zx.co.uk/forums/showpost.php?p=612631&postcount=5
Also the ones i sell I state the load rating, the material used and they all use Koyo sealed bearings, all very important factors for a componet that is constantly under strees and you should know this info when buying adjustable upper arms from anyone. :)
cheers
smithy
