Max Tyre Size on a 9.5 Rim?
Hi Guys, as above whats the max width of tyre i will get on a 9.5 rear wheel?
Thanks in Advance
Paul
prob looking at 285 as a max but i would stick with 265's personally
Thanks Mike,why stick to 265? i would have thought the wider the better on the rear?
Thanks again
Paul
Thanks again
Paul
less likely to rub if its been lowered and tbh i dont have any traction issues with my 265's just make sure its decent rubber :)
Paul, I'm running Toyo Proxes T1-S 275/35 tyres on 18x9.5J 41mm offset wheels and Eibach springs 0.8" drop with no problems.
Here is the data sheet I used: http://www.toyo.com/tires/tire_specsheet.cfm?id=2
-Andrew
I've got 275/30/19s on with standard suspension, during "normal" driving there is no problem but during hard cornering and through dips at speed the do rub a little bit. New suspension should sort that though. :)
