RichardS ·
Has Anyone seen the front mounted intercooler kit £599 advertised on Ebay by http://www.altezzasportsandprestige.com/Parts.htm
item number 120002441850
This is what he says on his auction: If you are interested... LET ME KNOW ASAP
as it is very important i can gauge the interest... as if there is enough interest i can lower the price even more!!!!
Could be a group buy if the guy is interested in doing one?
What do you think quality of this item would be like and advantages it will give?
