car running lean at more boost
had my car put on a rolling road today and anything over the standerd psi it starts to be lean i.e 11psi then 1bar.
the chap who done it knows his stuff and said it could be a fuel pump problem and might need a uprated pump.
so far i have nisstek stage 2 chip
decat
apexi boost controller
apexi exhaust system
at 1bar it was 367.2 at the fly wheel
is it normal to change to a uprated pump or is there something else that it can be.it does have a new fuel filter on it
any help on this please
kev
Very much doubt it would be the pump mate, yer no where near it's max flowing capabilities. Worth checking fuel regulator 1st but also timing is set at stock ( 15 degs) and not advanced at all. Have you a consult to check everythings okay ?
smithy
smithy
he did say the timing was not right but said that could be do to the chip
consult was on it when on the rollers
it did have a SAFC controller on it but was removed before i bought the car could this have done anything???
If your chip was also installed by nisstek, then they often retarded the timing so you would be overfueling rather than leaning out.
Not being from the mainland, ( so no idea) if yer not too far from kidderminster, arrange with John dixon to diagnose it for you, he can also check the map on the chip and see what's doing for you..
Either way, timing should be 15 deg mate, easy enough to check and alter.
cheers
smithy
cheers
smithy
ok do you have a number to contact him on please.
ok so it might be the timing didnt ask how far out it was but will ask him on monday
also it idels at just over 1k
Just PM him mate, think he's back around tomorow or Monday
Good luck :)
cheers
smithy
Good luck :)
cheers
smithy
just spoken to paul whos car it was and he said datascan was reading advanced at 25 would this be the reason you think ??
THat will be becuase you idle is too high. Fix idle problem and you should find it at 15 degrees at idle.
As for leaning out problem, get your fuel pressure checked.
ok whats the best way of checking this etc
