clutch fluid gone
could someone ive me some advice regarding the diasapperance of all the clutch fluid? is it possible it is the master cylinder or slave cylinder? how much for each and where from? and also who do i get in contact with regarding a cheque i sent to join the club a couple of months ago and havent heard anything from it? cheers
forgot to say i have had a look for a leak and there is nothing that stands out to be clutch fluid!
Cylinders would be available from MJP on here mate,as for your cheque,put a post in the membership section. ;)
fill it up and have someone press the clutch pedal repeatedly while you watch under the car.
surely you should see it leaking somewhere...
common culprits are the pressure hose to the slave cylinder or the slave cylinder itself.
thanks for the advic, i will check tomorow and report back, as for the cheque i sent to become a member was wondering who i could talk to regarding the where about of it as i definetely posted it 7 or 8 weeks ago!
thanks
