Couple of questions
The coolant pipe that comes out of the engine and two sender units. The big yellow one is for the fan, whats the little black one for?? (temp sensor??)
Also, how the FOOK do you get to it to get it out???? The big fan shield is kinda in the way!!!!!!
Thanks.
it is a bitch to get out. there's a metal bit of wire that holds it in, you need to squeeze the plastic bit really hard and then pry it off! or if, like me, just pull it off as hard as you can and then duct tape it back on!
are you just cleaning it?
Kinda wrote that wrong reading it back lol.
I got a new pipe (the metal bit with the senders in) which has been modified to fit a mechanical guage sender unit in. It goes inplace of the little black one, thats why I wanted to check if I can do without it.
But to get the fan shield out to gain access to the metal bit looks a complete f***er to change!!!!!!!!!
The smaller black connector is for your dash water temp gauge
Steve :)
'93 UK TT Manual
