avcr controller when off
found this on a old thread is this correct has i turned mine off today and seems to be like this
With the AVC-R off, and the standard boost solenoid disconnected (as you do to fit the AVC-R), you'll only ever be running "safety boost" - because the ECU can't open the boost solenoid to bleed off some actuator pressure so that you hit standard boost - which is 7psi or thereabouts - so 6.5 would be very nearly spot on..
yeah thats right.
thanks
been thinking something wrong with car
