Damn injectors
I just swap a tt for a na car didn't want to start, some explosion but not enough to make it run...
after I verify the coil packs, spark plug, fuel pump & injector connector (which i cleaned) 2V each idle
I bought a quick start bottle (fuel spray) spray some in the throttle body and the engine start good for the time it consume the quick start fuel.
how do I make these injectors work!!!!
Please Help!
I want to ride it this summer hehehe...
Need to change the fuel map (chip) as the ECU still thinks your running 265cc injectors when youve just put in 370cc jobbies!
Rich
did you install a TT fuelpump + controller also ?
otherwise, try the old (NA) ecu and see if it starts with that one. (for testing purposes only) it should start on a NA ecu, but run (very) rich.
don't drive the car with the NA ECU though !
I'm pretty sure these injectors are clogged, i guess ill have to remove the intake manifold to reach those !%$#?#$)(?@
seriously I can't remove the injectors from the rail whitout damaging them
is there any procedure? a tip, info.
Please.... :,(
Do you get a smell of petrol when turning the car over? Have you cleaned up your ECU temp sensor connector or checked the sensor? that can screw your fuelling right up
water temp? yes i've check the connector but havn't check the sensor ill switch it.
