Wheel bearing?
Ive noticed that when i turn left in my zed i now get a slight sqealing from the pass rear wheel. Its only recently started and seems to be worse if you corner hard left, but nothing turning right.
Im guessing this is the start of the wheel bearing going? How much to replace these? and is it an easy job (guessing not as it is a zed after all!)
They're available from MJP for about ยฃ120 each, not too dificult to do but you will need the use of a press to remove and refit the rotating hub section.
Baz
