Ok where do i start?
When i start my car it ticks over great,i can sit there revving it till im blue in the face (once warm of course) the trouble starts when i try to pull off it just wont :shock: It just fooks and farts like theres no fuel getting to it.
Where do i start to look?
Thanks guys.
Steve.
AFM, Vacuum hoses, plugs, diet (for the farting).
Have you got datascan?
But it's idling ok? TPS?
could be timing? changed your plugs recently? Fuel leaks/cloged filter....
Ahhh the joys of a 300ZX, just about anything can fail on it, and it usually does at some stage!
Yeh mate i know what you mean after 4 years of trouble free ownership its finaly all gone wrong at once.
Im off to Canada next week,but when i come back i think ill do a MarkZX on it and completely rebuild the bugger.
I would hazard a guess it has something to do with all the mods on the car unless your running an aftermarket ECU?
Hi Kirbz im not running much off the ecu only the RLTC and a RSM.
Do you think its too much?
I dont mean whats wired into the OEM ECU i mean if your running bigger injectors, bigger turbos etc etc the standard ecu wont run it well ;)
If you need any advice on what to do let me know and i will try to point you in the right direction :)
Mike
