I used my Datascan on anothers members car which came up with a code 34 error in the ECU which I cleared, but I also noticed his O2 sensor read between 3 and 4 where as mine reads between 8 and 9? Also when I started my car this morning after left standing over night my timing was at 25 which has now gone to 15 as normal after a run is this right? But all in all my Z is running as sweet as a nut. P.s it's an N/A
.........my timing was at 25 which has now gone to 15 as normal after a run is this right?
Yep, perfectly normal.
On my last cold start my timing was a s high as 35, no idea if thats right or not really ? After the run once it had warmed up went back to about 15, thinkive got a lazy left o2 sensor as well so that might be effecting the timing at idle when cold
hth
  • 3 weeks later...
