Hi All,
Just looking up Boost Controllers and the kind...can anyone tell what a RSM actually does? Just Meter the Revs and speed? Any idea of price on these fitted?
Ed
got a brand new one for sale with the g-sensor bud, looking for £200 ono
Measure:
- Engine RPM
- Vehicle Speed
- Travel Distance
- Battery Voltage
- 0-100m/200m/400m times with trap speed
- 0-100km/h/200km/h/300km/h times
- User Defined Mid Range Acceleration
- 4-way front/rear/left/right directions G Forces
- Horse Power
- Loss Power
Also includes:
- real time graph mode, numerical mode, or analogue mode display
- ability to display 1-4 channels at a time
- Peak Hold, Replay (With 60 second playback.) options
- Speed Limiter Cut
- Wheel-Spin Correction
- lots more, see below…
"Like the original, the new Rev/Speed Meter GP is a complete multi function measuring device designed to measure and monitor data such as vehicle speed, engine RPM, and elapsed times. However, the strength of the new unit lies in its differences. Probably the most obvious being its completely redesigned look.
This new aesthetically pleasing model was crafted to match the likes of other highly popular A'PEX electronics such as the VAFC (VTEC Controller) and the AVCR (Boost Controller). The new screen utilizes the easy to read VFD (Vacuum Fluorescent Display) with built in light sensor used in many of A'PEX's line up.
The new unit also delivers a host of new functions. Standard features include: Engine RPM, Vehicle Speed, Travel Distance, and Battery Voltage (All which can be displayed in real time graph mode, numerical mode, or analogue mode; 1-4 channels at a time.), Peak Hold, Replay (With 60 second playback.), Speed Limiter Cut, 0-100m/200m/400m times with trap speed, 0-100km/h/200km/h/300km/h times, Mid Range Acceleration (The user can preset any range of speed to measure.), Stop Watch functions, Best Time Memory, RPM Warning, Speed Warning, RPM and Speed Outputs (For external devices requiring an RPM or speed signal.), Tire Size Correction (For acceleration and timing accuracy.), and Vehicle weight input.
One of the most exciting of the new features is the option to utilize the revolutionary A'PEX G-Sensor. The G Sensor allows the unit to measure G forces in 4-way front/rear/left/right directions. This data can be plotted in a graph display to map acceleration characteristics and lateral G's on the race track, or used in an array of new features including: Highly accurate 100m/200m/400m times with trap speed and wheel-spin correction, Horse Power Calculation, and Loss Power Calculation. By taking advantage of the optional G Sensor, the user can produce extremely accurate power measurements. Usually, when measuring 0-400m times through the speed sensor signal alone, the meter will end measurement too early (shorter distance) due to wheel-spin. Using the G Sensor modifies the speed sensor signal, compensating for wheel-spin and producing impeccably accurate acceleration times."
A'PEXi
Measure:
- Engine RPM
- Vehicle Speed
- Travel Distance
- Battery Voltage
- Horse Power
- Loss Power
Also includes:
- Speed Limiter Cut
A'PEXi
thanks mate - may be a few weeks till i buy though..
no worries bud, just let me know if/when you want it :)
