Bushes!!!
hi guys! getting a slight knocking :headvswal from the rear left of the car when i go over bumps as though somethings loose, now which bushes are the most prone to wear as ive only got £100 to spair and dont think i can afford to replace them all on the car.
cheers in advance. ;)
The most common to wear are the Hicas bushes, but could be any of the rear arm bushes, but knocking is not a usual sympton if wear.
Check your Rear subframe bushes and suspension mount bolts are tight.
hmmm! yeah just presumed it would be the bushes, i suppose they'd have to be pretty worn to knock!! i guess ill have to get the arse end in the air and check its all tight.
cheers legrath.
